Charleshugh
Registered Member
Hey guys, My front two tires had a good amount of camber so I changed the wheel bearings yesterday but it only fixed one tire. I can grab the top and bottom of the tire and wiggle it a little, it’s not a lot of wiggle but it’s still there. I pulled the shaft that leads to the front diff to check the U joint and the U Joint was right and had no play in it. Any help to figure this out would be greatly appreciated.
Thanks,
Hugh Kennedy
Thanks,
Hugh Kennedy
