BowtieBlazer
Diesel Powered
I just purchased a 88 blazer from a friend of mine, it sat up for almost 3 years without being bumped over. I got it running after a little PM. This weekend I had the motor at operating temp running and went to adjust the timing I read in chiltons to disconnect the plug from the distributor cap to get rid of the computer advance and check the timing like that. I pulled one of the two plugs and pulled the wrong one as the motor immediately shut down, and since has not restarted even with the plug reconnected. No spark and now the injectors are no longer firing. The fuel pump relay is new and so is the coil. Did I zap the ign. control module? Other ideas?
