hytech_rednek
Registered Member
I have a 1989 6.2L diesel (stock Banks turbo). I am having trouble getting it started. I thought I ran it out of fuel, added more fuel. This what I have done so far:
New Glow Plugs (2 months)
New Glow Plug Controller (3-4 months)
New batteries (3months)
Cracked open the injectors and cycled the key until all injectors had fuel coming out of them (still no start, but cranks strong).
Lifted turbo off manifold and used WD-40 while cranking engine (no change).
Engine heater has been plugged in to keep block warm so I am not burning up glow plugs/controller.
Have cranked engine enough to require recharging batteries.
I am thinking that because the WD-40 would not fire the engine it may not be a fuel delivery problem, then again I am a bit green at this.
Any and all ideas will be helpful.
Ok, after doing more research I found out it could be air-locked...went through the proceedure and no fuel is coming out of the air filter when I remove the plastic screw and crank the engine. Possible fuel lift pump? Hopefully not an injector pump! Now I am wondering why fuel came out of the injectors...left over from the injector pump possibly?
Thanks for the input.
Tim
1989 K-5 6.2L Turbo Diesel 4x4
3" suspension lift
33x12.50x15 Pro Comp tires
Tim
3" suspension lift
