Earldub21
Registered Member
I have a 1989 Chevy Suburban V2500 Silverado with barn doors for sale. I have owned this for 25 years and its time to let it go, divorce forces sale. Asking 10k but open to reasonable offers. Clean title. It has 350 TBI, factory manual transmission. 6 inch suspension lift with a 3 in body lift and has 37x13.50x16.5 humvee tires on it. I change out the transmission from the SM465 to a NV4500 from a 91-95 Chevy one ton. It has an advance adapters bell housing to run the factory external slave cylinder. It has a NP241C transfer case. The rear end I rebuilt with 5.13 gears with a posi-loc in the rear and disc brake conversion. It does not have the parking brake calipers, when I did the conversion I couldn't source them at that time. Interior need some work, the carpet has been removed and the seats dont have any tears but the foam on the arm rests need to be repaired. It has all three rows of seats. The headliner needs to be redone as well. It has a roof rack. Only has surface rust. I have another set of newish military 37 tires that have like 95 percent tread, and another set of slot mags that will come with it. I have a gen VI 454 for it that has been torn apart and need rebuilding. Edlebrock pro-flo 4 fuel system. I also have a gm dana 60 front axle for it. It doesnt have 4WD hooked up. When I swapped the transmission I bought a JB fab transfer case shifter that I haven't installed. Asking 10000 OBO. Let me know if you have any questions. I am working on getting some interior pictures.
