1989 k5 1 ton part out
do you have the taillight harness plugs in good working condition? see attached pic.
also how are the cab corners? mine are rotting by the door/rocker/rear quarter area, i need some solid corners cut out so i can weld em in my truck, thanks
i do have the taillight harness, it does work, have not seen what it looks like so not sure of condition but its worked for me.
drivers side front is the only corner that has NOT rusted through
I was looking for a tach. How about the radio and speakers? Pics please??
shifter assembly, seat bracket, tail light harness
light harness i am not so sure its the whole right part? let me know if right or wrong
could not find the air cleaner assembly, i will keep looking for it though
how is the wiring on it any problems or shorts? if its all good how much for complete harness and fuse block not really wanting a bunch of cut up wires thats what i got now lol and also does it have a good steering box with no slack or leaks and the steering shaft if its in good shape too
i had no problems with it, i will check what it looks like when i get down there next time.
steering wheel had some play in it, not sure if it was because of the steering box or not but there are no leaks in it
Good shape no dents, no power tools or power where the truck is so don't think its comin off easy
You could take it off with a cordless drill if you drill out the spot welds. Not asking you to though because it is a PITA. Let me know if it becomes a possibility and how much you would like for it. Thanks.
