1989 K5 Blazer Rockcrawler, D60, 14 Bolt, Detroits, 39.5" TSL, Beadlocks
wheelingdrummer
Boulder, Colorado
1989 Chevy K5 Blazer Silverado
This is my baby and I hate to sell her, but I’m only driving her when it snows and I’m really sick of being in debt. I bought the truck in April of 2008 and it was pretty much stock. All of the modifications have been done by me and/or Darren Castine at Twizted Engineering. I have most of the receipts for everything that I have purchased for it. When I ripped out both axles to put in the 1 tons, I and ground down the frame, primered it and gave it two coats of undercoating. Most of the parts underneath that are after market have been powder coated a beige color, color code BG-16. The top has never been off and I remove the doors during the summer time. Forest Green Metallic Exterior paint with tan top and interior. I do not NEED to get rid of this truck but I will sell it if the price is right. If you are seriously interested then give me a call with an offer.
Check out the photobucket album with every picture I have from start to finish:
http://s75.photobucket.com/albums/i287/wheelingdrummer/1989%20Chevy%20K5%20Blazer/
Front Axle:
The axle was ground down to bare metal when I pulled it and primered and painted semi gloss black.
Dana 60 out of a 1988 K30
5:13 Yukon gears
Detroit Locker
Solid 6 studded passenger side Knuckle and high steer arm
35 spline Yukon chromoly outer axle shafts
Warn premium hubs
Steering:
Crossover steering
3/8 wall tubing on tie rod and drag link
1 ton tie rod ends
PSC hydro-assist kit:
-PSC steering box
-High output pump
-Remote reservoir
-1.75” cylinder size
-Power steering fluid cooler
ORD weld in steering brace
ORD bolt in steering brace
Twizted Engineering high clearance engine crossmember with Track Bar
Rear Axle:
GM 14 Bolt out of a 1978 K30
5:13 Yukon gears
Detroit Locker
DIY4X spring perches to move axle back 1.5”
Crane diff cover
Shaved over an inch for clearance
Suspension:
Custom Alcan springs
Springs were made as soft as possible
Heavy duty greasable bolts on all bushings for leaf springs
Very long stainless steel braided brake lines
Front:
52” (eye to eye) 4” lift front springs with orbital eyes toward the rear of the vehicle
DIY4X B52 kit with 7.25” rear shackles
ORD heavy duty shackle hanger
Rancho shocks
Rear:
64” (eye to eye) 4” lift rear springs with orbital eyes toward the rear of the vehicle
Stock front shackle hanger moved forward
Twizted Engineering custom rear shackle hanger
DIY4X cross tied shackles modified for orbital eyes
Twizted Engineering custom shock inboarding conversion
Fabtec shocks
Drive train:
Stock Chevy 350 TBI Fuel Injected
Newer starter
Newer alternator
Newer fuel filter
Dynomax headers
Custom dual exhaust that dump into Flowmaster 40
Energy Suspension engine mount and t-case crossmember bushings
Just rebuilt 700R4 transmission with many heavy duty parts
Transmission cooler
Just rebuilt NP241 transfer case with slip yoke eliminator (welded reinforcements)
CV extra long splined front driveshaft from Front Range Driveshafts
Rear driveshaft from Front Range Driveshafts
Tires/ wheels:
39.5 x 15 x 15 grooved Super Swamper TSL
15x10 rockcrawler beadlocks with 3.5” backspacing
Full size spare that is also grooved on a 15x10 “D” window wheel
Set of 33” roller tires on 15” wagon wheels
Interior:
B&M Truck Megashifter
Cobra CB radio with 4’ Firestick antenna
6 disk CD changer located under the driver seat
Keyless entry with remote start
Auto windows and door locks
A/C blows cold!
Heat blows hot!
Miscellaneous:
1/4" Rocker guards
Wheelbase has been stretched to 110” (3.5” longer than stock)
Twizted Engineering winch cradle with sides
Smitty Built 8000XP winch
4 rocklights located at each tire
Quick release door pins that I made at the machine shop I work at
Quick release door wires
Sticker on the windshield that reads IF YOU CAN READ THIS, YOUR JEEP IS UPSIDE DOWN (upside down of course), I have 2 more stickers because I had to get them custom made and buying in bulk was cheaper.
Spare Parts/ Tools:
Since I will no longer have an off road vehicle I have many spare parts for any trail breakdowns:
Large tub full of all fluids needed for the truck
Upper and lower radiator hoses
Spare stock outer front axle shafts with hubs (Both 30 spline)
Multiple U-joints for driveshafts
Spare independent steering box (not ported for hydro)
Front 1 ton tie rod end (slightly bent but usable)
Pitman arm puller
Come-along
Many more random tools
Stock rear bumper
Serious interests only, Thanks!
$8,000
Thanks for looking
Kyle
(720) 394-5660
Still have the truck and looking to get $8,000 for it. Really don't want to part it out since I no longer have the space to do so, but if it gets down to it, I might have to...
