1989 K5 Help
Randybt
Registered Member
Waterloo, IL
I purchased this Blazer in May, rainy day looked better than what it was. The cross member body mount under floor behind driver & passenger seat is broke at both ends, really sucks! What I need is the measurement between doors or length of the crossmember. I have tried without any luck to find this information, maybe one of you can help. I have the new parts, basically a new body and mounts. Thanks in advance!
Ok, let me verify that you are needing to set the width of the frame at the front of the rear spring hangers, correct?
Hi and THANK YOU for replying back. There is like a crossmember that runs from side to side just behind the doors, there is a body mount on each end (next to frame) then the crossmember is welded inside each door column. Both of mine are broke at the welds so the body has spread some, when I weld new ends on crossmember I need correct length. Thank you for all the help!
