1989 Toyota 4runner
199,446 miles
Four Wheel Drive
Manual Transmission
Manual Doors
Manual Windows
Functional AC
Removable Top
Bluetooth Radio
I bought this from a friend before he passed from cancer a year ago. He'd had it since 2006 and it was his dream truck but it hadn't ran since 2006. I was hoping to get it running before he passed but that didn't happen. I've spent the last year getting this thing rehabbed and running again and now it's time for it to go to a good home. In the last year the following has been replaced:
Brake Booster
Brake Master
Rear brake shoes
Rear Wheel Cylinders
Rear brake rubber lines
Front Discs
Front Calipers
Front Brake rubber lines
Clutch Master
Clutch Slave
Clutch rubber lines
Fuel Tank
Fuel Pump
Radiator
Engine Belts
Alternator
Spark Plugs
Spark Plug Wires
Distributor Cap
Distributor Rotor
Ignition Coil
AC Recharged W/r134
AC O-rings replaced
AC Ducting resealed
Evaporator Coil cleaned
Fan motor box cleaned
New Carpet
Idler Arms
Pitman Arm
Tires
It runs, drives, passes inspection, is currently registered, and I have the title for it. Been driving it around town for the last year off and on and it's been fine. I've got a new set of ball joints to go with it. Price is $4500 obo.
199,446 miles
Four Wheel Drive
Manual Transmission
Manual Doors
Manual Windows
Functional AC
Removable Top
Bluetooth Radio
Brake Booster
Brake Master
Rear brake shoes
Front Discs
Front Calipers
Clutch Master
Clutch Slave
Clutch rubber lines
Fuel Tank
Fuel Pump
Radiator
Engine Belts
Alternator
Spark Plugs
Spark Plug Wires
Distributor Cap
Distributor Rotor
Ignition Coil
AC Recharged W/r134
AC O-rings replaced
AC Ducting resealed
New Carpet
Idler Arms
Pitman Arm
Tires
