Not likely at all.
Check your fuses. Pretty sure you've got a fuel pump one. Take a wire with you, and run it from the battery + terminal to the red wire hanging off the relay on the firewall. That will force the pump to run. If you have another relay, swap it, just in case the relay is bad internally. (I'm not saying replace parts...just if you have a spare relay, try it....the '88+ C/K's used the same relay style for the AC and fuel pumps, so those are easy to swap to test, not sure if the R/V trucks got the same setup) The truck SHOULD still start after about 10 seconds of cranking even with a bad relay, since the oil pressure switch should close, but if it's failed already, it wouldn't start.
Also realize that the pump won't turn on every time you rotate the key to run. There is about a 10-15 second timer in the ECM, you'd have to wait at least that long between each try to actually hear the pump run, if it's working.
