1990 6bt injection pump drive gear cracked !
mill5471
Metamora, Michigan
1990 6bt injection pump drive gear cracked ! its not a P pump believe its called a VE pump. doing some work on my buddies truck, water pump, radiator,t stat and check/fix the killer dowel pin. pulled the front cover off and found this!
where the fock do you find a new/used drive gear at??
edit: ya VE pump, found one on ebay for 60 bucks shipped might have to get it.
thanks. theres one not to terribly far away ill give them a call, i'd rather buy local than have spend on shipping.
ever heard of one cracking before?
