So originally the 1990 would have been a R12 system, at this point not knowing the vechicle history I have to beleive someone converter to R134 because it appears they put the fitting conversion pieces that you screw onto the existing R12 fittings. The system is not makred anywhere which they usually would be if converter professionally. My question is can I replace the seals and put R12 back in the system or shoud I install R134 back into the system?
thanks
thanks
