Does anyone have a wiring diagram for the AC system.
thanks
thanks
tons here... looks like the light and dark greens are connected..
http://www.truckforum.org/forums/chevy-truck-forum/36278-electrical-diagrams-chevy-only-2.html
So I am confusing my self a little, when I check continuity from the lt green on the pressure cyling switch to one of my mystery wires I get continuity as long as the ac clutch connector is connected...I am not seeing how that is happening based on the schematic as the light green wire goes to the relay and I would have expected this condition on the dark green wire at the cycling switch
The clutch connector is ground for the system, so disconnecting you'll get an open
On that schematic the lt grn connects to the dk green prior to the relay, between the pressure switch and relay
Let me go back and re-read your original post...
**edit*** at this point I would unwrap the harness and trace both ends of the cut green wire. On the schematics I linked there are a couple for the bulkhead connector pinouts.
Does your AC work? You mentioned cruise control in the first post.. have you traced the wires to it yet?
Yes. Just jumper it for a few seconds. If the clutch engages, then your A/C wiring is complete, assuming it's like the mid 80's trucks or like the diagram posted above. (I don't know why they have a clutch relay but still run full coil current through the pressure switch - it appears they are only interested in saving the dash switch.)
(BTW, it's confusing having 2 threads about the same thing)
The "continuity" is probably a few Ohms, not 0, since by your test, it is clearly the A/C clutch coil.
Did you ever state whether or not an engine swap had been done in this vehicle?
