douglasboys
Newbie
I have a 1990 Blazer with 10b front and rear. The truck is mainly used off road on rock and dirt trails as well as blasting through dunes. I broke the spider gears in the rear end and from what I’ve read, I should upgrade to 14b. I just put on 33”s on 15” wheels which will have to be replaced with at least 16”? My question is what 14b should I use to make this easy, affordable and reliable? What years and vehicle would I find it? Will it bolt right in to the leafs and drive shaft(s)?
The Blazer does not do well on whoops or rough roads, has anyone switched over to a coil spring set up using newer axles? Is it time to sell “The Money Pit” and look at a newer Explorer or Cherokee?
Thanks
Thanks
