TPCLARK
Registered Member
Hi! I have recently finished a 1 ton swap on my blazer, and we are trying to figure out power steering that can turn the new 37" tires. The old system with the stock pump, steering shaft, and steering gear used to turn 35s. I've installed a redhead steering gear, and a Borgeson steering shaft, but the stock pump wont push enough to get solid steering. It drives like there is none at all. I am curious if anyone out there knows of a good pump that pushes more fluid than stock, or if I should just get a new stock pump.
