Queasyrida
Registered Member
The ball joints checked perfect, top and bottom both sides. Steering box bolts tight, no cracks in the frame.These solid front axle trucks will never steer as tightly as a car, but you can get them reasonably tight. I'm going to mention looking for frame cracks around the steering box just to be thorough...but with it's low mile/easy driving history and on small tires I'm 99.9% sure frame cracks aren't a problem on your truck. Still good to get a socket on the steering box bolts and check them though.
Ball joints could just have been not greased much in it's life, it's not necessarily abuse or hard driving that wears them out.
I did have a slight wheel bearing (?) wobble, drivers side. You could feel it more than see it, pushing the top of the tire in and out. Is the bearing adjusted the same as a 2WD front axle, tighten the nut and then back off slightly? I removed the chrome axle cover held by six screws but I stopped there not knowing what to do...
