ethanthatcher777
Registered Member
My blazer runs fine until it gets warm; then it dies at idle. I've replaced the TPS, ICM, IAC, fuel pump relay. O2 sensor is working according to live data on my Snap-on scanner aswell as the MAP. Fuel pressure is good, has a new fuel pump. The coil is good and strong. When it tries to stall, you can sometimes keep it running; it'll run like its running on 1 cylinder for 4 seconds, then recover, and repeat. If you Let it sit for 10 minutes it'll start idling again but it'll start doing it once you drive. And this just started out of the blue one day when I had to crank my truck over twice because it'd stall once since then it's been downhill.
