1990 door panel on 82 blazer?
Kray
Registered Member
Found some really cool red door panels that look like everything I’ve been looking for but they’re from a 1990 square body suburban and I have a 1982 blazer. Will these fit just fine ?
I'm pretty sure all of the '81+ door panels are the same size and bolt pattern for the screws. The differences will be the options, obvious things like power vs man plus if it has a pull strap there might be an anchor bracket behind it so you'll need that stuff too.
