1990 front quad shocks
snowdriver
oregon
need to replace my front shocks,everything is stock on this blazer,but am wondering if any of you have had better luck with some sort of single shock,or just do another set of quad shocks,thoughts?
Just run a single shock on each side, but use the upper auxiliary shock mount, so you can run a longer shock than the standard short single front shock.
Martin
If you ordered quad shocks for the front, just use the longer shock.
Martin
