STOCKERS if you need to smog...![]()
if your looking for shorty's, save your money and keep the manifolds...
Shorty headers don't make as much power as a tuned full length header...
Manifolds will pass smog easily and make your engine get to operating temp faster, also will work with your factory o2 sensor, and the bolts never come loose. If you get headers, you need smog headers, you also need to fab a heat-riser, mod the powersteering bracket, the y-pipe cut back and welded, and the o2 sensor bung welded, might even need a heated o2 sensor if located far enough down stream.
no header will pass smog
Your STOCK header will pass smog....
"Stock", "stocker"....
And, yea.... There are CARB sticker'd headers.
So you're wrong, anyhow.
Gawd I'm a dick...![]()
Bah.... I read it as a statement.
Yes there are some.
I'll try to find the link.
The crappy part, is you can't legally eliminate the Y-pipe.
And, that's the most restrictive part....![]()
So it's running now?cool thats what i wanted to no so i guess i stick with stock i just wanted to see if i could get alittle more power out this stock motor
