1990 K5 383 fresh rebuild. ticking...
Have you run it without the accessory belts to make sure it's not coming from something there?
If you do this, don't let it run for more than 30 seconds to a minute, the belts spin the water pump. No pumping, no cooling. Seems like common sense until that one time you forget :screwy: :confused:
Is it a flat tappet or a roller cam?
Martin
Thanks for the replies guys. I am not sure if it is roller or flat... I need to pull the intake. I will have some more time to look at it this weekend. I will keep you posted. Thanks again
