k mac
Newbie
I heva a 1990 K5 and want to know of anyone has tapped into the passenger side fender for fresh air intake.
did you look at the factory setup ? the tube goes to the core support and pulls air from before the radiator in the whole grill area . think about it as its almost cold / ram air in a way .I heva a 1990 K5 and want to know of anyone has tapped into the passenger side fender for fresh air intake.
If you look back in the waybacks of this site @dremu did something like that on his stealth dually years ago. Modified an air intake to have twin snorkels going to each side of the core support.A while back I had a thought of taking advantage of GM’s front radiator support fresh air ( which works great ) intake setup but make it a dual air cleaner inlet.
Similar to what GM did back in ‘83~’85 on the Camaros with an L-69 H.O. air cleaners but instead of using the old carburetor air horns you could use the later truck ( possibly larger ) TBI air cleaner assembly.
You could use a TBI engine ( pictured is a ‘89 TBI 454 ) R/V series air cleaner with a passenger side air intake and fabricate a driver side air intake horn off of a ‘88~’94 GMT400 to the cleaner assembly.
Finish it off with the plastic plumbing off of the truck stuff routed to the front support because the Camaro junk is sandwiched between the hood and support.
See attached pics for visualization help.
Just a thought I had years ago - might help ya’ .
