this is not ideal situation during a 30" snow fall right now....
"I think the ECM system has grounds on the front of the block by the thermostat housing and on the back of the block on the passenger side"
so these grounds would be like the master ground for the ECM? Does the ECM housing have a ground to the metal case? It appears that my ground at the thermostat housing is good, I would almost rather extend that to the battery.....
still trying to locate the ground on the passenger side back engine block....
engine block ground braided wire is good and good ground, going to go drop the ECM down see what I can figure out there.
So pulled the ECM out, testing all the ground wires for continuity and all ring out good. Put the thing back to gather and plowed for 1hr no issues...
at a loss....
