1990 Suburban
hidesertwheelin
Hesperia, CA
I'm selling my 1990 Suburban 4X4. I'm just not into off-roading anymore. It runs great, but if you live in an "enhanced" smog area, it will not pass smog. It is blowing 100 ppm to much NOX on the dyno @ 25 mph. Other than that it passes no problem. Here are the specs.
350 tbi w/ 149k miles
New Bow Tie Overdirve 700R4 tansmission (less than 500 miles on it)
Rebuilt Np-241 transfer case (clocked flat)
Rebuilt 8-lug GM 10-Bolt front axles, with 4:88 gears
Rebuilt Gm 14-Bolt FF rear axle, with 4:88 gears, Detroit Locker, disk brakes, caddy calipers w/ parking brake.
4" lift springs in front w/ 1" zero rates, and axle moved forward 1"
4" ORD shackle flip in rear w/ 1" zero rates
4 core radiator
Dual batteries
Full length roof rack
Custom front and rear bumper
Warn M1200 winch
35" tires
Asking $3800 as is obo
