Truck died about a month ago. See post started on 3/18. Shop replaced the distributor and it worked. However it happened again a couple of weeks ago. The same blown fuse ECM B indicated it was the same problem. In assessing the situation. the distributor was new and mostly mechanical with the only solid state part the Ignition Control Module. So I took a chance without really knowing and replaced the ICM. It worked. A commenter on my first post had the same problem and it was in his case caused by the air cleaner box shorting wires with worn insulation. I checked and it looked like there may be worn insulation on the plug wires to the ignition coil. So as part of last fix I wrapped them is electrical tape and hoped I was good. Not so. It died again today. How do I track down this intermittant problem? Could it be the Ignition Coil? More lost work. this thing is killin me. Thanks.
