When I bought the truck it had a clutch fan but with really heavy pitched blades. There was no fan shroud and 2 core rad (I think) that was 39” but only 17” tall instead of 19” (I think that’s right), regardless it wasn’t the right one and it leaked a little, so I replaced it. However, it also cooled almost too well with the same characteristic long warmup. Driving it home 3 hours on the highway with it wound up just over 3k rpm at 65 it never got above 160 I’d guess.Fan clutch eliminator, is partially to blame for long warm up. Also no trans cooler in rad.
That the same radiator as pre full electric fan?
Cool Vette.
Yup, I’ve come to the same conclusion.I'm guessing it's got no thermostat or one that's stuck wide open.
Those are similar to these, just no “454” plaque, right?Ive got some boring old 98 vortec valve covers if you like those.
Appreciate it, I’ll let ya know. Do you still have the 4l80e/xfer case adapter?Yeah they are no beauty queens but you can have them. Im just south of New Braunfels in Cibolo. Come get em if you feel like.
Mag wheel cleaner spray with oxalic acid might clean those up good.
I've used that on several "moldy" aluminum intakes that sat forever and they came out pretty clean...glass beading works better though if its really bad..
Didn't look that close..Look at the gasket lip of the covers, in some places it’s gone.
--guess they are good for shop wall art only now..
