1991 K5 $3000 in Boise
Nampa Idaho
http://boise.craigslist.org/cto/4128030773.html
1991 Chevy K5 Blazer
- TB injected 350 185,000 miles
- 700R4 overdrive automatic trans. Rebuilt 100 miles ago w/TCI Torque-miser clutch packs, Corvette cams, TCI Truck-master torque converter, and deep fluid pan.
- NP-241 Transfer case W/ slip yoke eliminator, Energy Suspension mount.
- Denny's CV Driveshaft with R3 joints and long slip shaft, 100 miles.
- Axles GM 10 Bolt. Rear, Yukon chromoly 30 spline shafts, Detroit Locker, and 4.56 gears. Front 30 spline shafts, Warn Premium hubs, and 4.56 gears. Rear shafts, hubs, gears, locker, front u-joints, all bearings and seals installed 500 miles ago.
- 6 inch Rough Country Lift, all springs no blocks front and rear. Off Road Design shackle flip kit and Zero Rate spring in rear. Rough Country shocks, quad in front, two out back.
- Steel braided correct length brake lines.
- Drop pitman arm and lowered connecting rod, steering is on point and works well on the trail.
- Custom front and rear bumpers. Rear spare tire carrier, jack and Jerry can carrier. Built in shackles.
- Power windows, locks, A/C and heater work great. Interior still good states are in great condition, front and rear.
- Off Road Design steering box brace.
- 35" Cooper Discoverer S/Ts on 15x9 aluminum rims.
Do your research before you call me. There is over $6,000 in parts on this rig. It is ready for the trails now or you can do some body work and paint and restore it. Or, it would make one hell of a doner for your any year blazer pick-up or buggy project.
I have a new project and will be using the funds from this to fund the new build.
First $3000 takes it.
I really don't want to get rid of it but I bought a FJ40 that needs lots of work and I can't maintain both.
O.K. You got me, wife said one has to go.:doah:
