1991 Suburban bulkhead diagram
I can find some on AllData also. What circuit are you specifically looking for?
I'm integrating my LS harness into the factiry harness so I was just deleting everything not needed for the TBI so I could keep all the non engine accessories operating properly and tie fuel pump and 12v ignition into the bulkhead among other things.
That link is having an issue. I used it earlier and it was fine.
Try right clicking and hitting open link in a new tab.
The link doesn't work for me either. I wonder if you need a user log in or paid account to access.
The wiring in my 91 Blazer wasn't necessarily hacked but it needed to be reworked significantly. When I rewired it, I isolated the wires I needed (wipers and starter) and removed everything else from the bulkhead plug. That said, I did not retain accessories (HVAC, cruise control, etc.).
I also added an aftermarket fuse block (from Blue Sea Sytems) that I used to feed the alternator, electric choke and fuel pump (I added a relay into the fuel pump circuit too).
