1991 Windshield Wiper Switch - Delay/Pulse
Rhinodrvr
Registered Member
Pensacola, FL
Anyone have an idea where I can find a switch for my 91 K5? I found a second one, but it was bad also. Obviously OEM is not an option and I am getting desperate.
What are the problems with the wipers?
I had mine act up and tried a switch that I had, then a pulse module. Turned out to be a problem in the motor.
Did you check Rockauto?
If it's the turn signal stalk with the switch and stuff Amazon, rock auto, auto parts store. GM used those turn signal stalks in alot of cars.
Then it could be the motor itself. Or it could be the intermittent under the column.
Do they not turn on at all?
