pevrs114
Registered Member
Gents,
First off I wanted to say hi. I've been a lurking member here for years, but finally paid up and can post. Some of you may recognize me from AR15.com or SteelSoldiers. I have a few quick questions regarding a truck I'll be getting next week, hopefully you guys can give me a hand.
I'm going to pick up a 1992 full size Blazer. It's extremely clean, no rust, and well maintained. It has 88k miles on it, with a stock drivetrain (350tbi, 4L60(not e), NP241, 10 bolt, and IFS front. I'm assuming it's 3.73 geared, but I haven't confirmed it. It's a Silverado edition, with plenty of power options. It's bone stock, other than twin tail pipes and a bit of chrome flashing (yuck).
I'm already looking at upgrading it (hey, who isn't?). The primary use for this truck will be a capable daily driver, which can tow, do light off-roading, camping, and general reliability. I'm not looking for anything extreme, but I'm planning my mods now to be overstrength and overthought for what I'm looking to do.
I already have a Warn Classic bumper and a Warn M12000 for the front. Plenty of comm gear and standard compliment of recovery, camping, and bail-out equipment to keep inside.
First issue is springs/lift/tires. I'm considering running a BFG AT in 33x10.50, which is a narrow tire. I'd prefer not to incur the costs of regearing, hopefully the truck will be able to run these without significant loss of power or strain on the front end. Will a standard 15" steel wheel from the square body style fit over the brakes on this truck without any problem? Would I run into any backspacing issues?
I'm considering upgrading to K3500 torsion bars for the improved GVWR, especially with the heavy winch on the front. Will they drop right in with minimal fuss? Will I need to adjust them to clear the tires, and if so, what would be a good set of keys to do it with? I have a PN for Ford expedition keys, but I've gathered they just fit the half ton torsion bars. I'd really like the increased weight rating of the one ton bars. Anybody have a PN for keys and torsion bars that will help out?
Down the road, I'm considering a 6 lug 14SF and 4L80E. I don't really plan to wheel this truck hard (I have other vehicles for nasty trail riding) so I don't see the advantage of a SAS. Thus, I want to keep 6 lug in the rear. I figure the heavy half rear would provide an upgraded towing, braking, and strength capacity while minimizing the snowball costs of 8 lug projects. What years and models does this axle come in? Any gremlins to look out for?
I'm also considering a 4L80E for the same reasons. I'd like to keep an OD transmission, otherwise the TH400 I've already got would work just fine. What is a good expected range for a well-maintained used heavy duty trans? Any problems bolting it in place? I've got the TH400/208 combo already so the adapter should work to connect the 4L80E/241, correct? Any changes in driveline length? What will I need to do to run the electronic part of the trans, as the current trans is not an -E model?
Sorry for the barage of questions, I'm new to the IFS series of trucks. I am not looking to make this thing hog-wild, it will probably end up looking mostly stock on the outside, but I'd like to strengthen it up for durability and reliability purposes.
Just so no one worries, I've also got an 80 CJ7 and an 86 K30 CUCV to play with. The K30 currently has an oak tree sitting on the cab DOH! So it's drivetrain will get scavaged and combined with other stuff, hopefully into a square body crew cab!
Thanks in advance...
