- Joined
- Mar 3, 2000
- Posts
- 9,123
- Reaction score
- 7,076
Looks like I need to swap in a new power steering pump in the jimmy.
It has a Motor out of a 93 suburban in it. Took a quick look at how to take it off but wanted some advice before I start ripping into it.
looks like there is an allen type open center in the shaft, so do you first need to take the pulley off this style to remove the pump? It appears the bolts that hold the pump to the bracket are behind the pulley. So somebody give me power steering pump removal 101 class. I haven't bothered to pick up a manual for this motor yet. Just don't want to take off more stuff than I need to.
Obviously take the serp belt off, then maybe take the pulley off. Any special tools required? Then remove mounting bolts and obviously the lines.
Thanks.
Thanks.
