Yo, I'm asking some question for a co-worker since it seems he's getting bad advice from a mechanic about his truck. I'll go over some of the odd things about the truck.
*****Thermal temp reading of the water neck says 200*, but the dash gauge says 160*. I think the temp sender is wrong. Originally I thought the stat was bad. My personal truck reads 190ish*, but it has a 180* stat. There is no way his truck is running 160* and have the water neck surface be 200*.
*****Truck stinks. Really rich and I can smell it driving behind it. I think this might be connected to the temperature sensor. Not sure what temp the "choke" turns off, but if the engine thinks it's 160*, that might cause problems.
*****The exhaust manifold temperature coming straight off the heads reads odd. Driver side is between 400-450*. The temp on the passenger side is 500-550*. The rear cylinders not always being the hottest. The temp was taken ofter coming back from lunch, warm engine @ idle.
*****If you hold a piece of paper or a dollar bill next to the exhaust.....it blows in and out. Not sure what that means, like it's sucking the dollar bill back in. I don't hear any exhaust leaks, so I'm worried.
*****Mechanic told him he has a cylinder down, or warn, or something. He said it was #5, but the exhaust temp doesn't show any difference.
*****The truck uses no water and the exhaust emits no colors or smells of oil. So if there is a problem with a cylinder, it's in the valve seats. I don't believe the engine to use any oil. The oil pressure is remarkable (if you believe the gauge) with ~35-40 @idle and ~55 @highway.
I don't know compression. I know all hoses, belts, alt, spark plugs, wires, cap, and rotor are all new. It doesn't have a lope, but it does seem to have a big hole where it's balls used to be.
I drove it some and at one point it had a hiccup or cough and sputtered for a second, then picked back up.
Just wondering if this engine is even worth trying to diagnose. I told him he could slap a 5.7 in there with damn near no modifications.
I drove it some and at one point it had a hiccup or cough and sputtered for a second, then picked back up. Just wondering if this engine is even worth trying to diagnose. I told him he could slap a 5.7 in there with damn near no modifications.
