1994 jeep grand cherokee
K5dreamer
Alexandria, Va
a friend of mine is looking to buy one of these, she's going to look at it but im stuck here at work waiting on a customer to show up. So im trying to give her a list of things to check out. I already covered all the used car and 4x4 specific basics, but does anyone here know of any known problems with that year of grand cherokee?????
Its a 1994 Jeep Grand Cherokee, I6 auto, 4x4, supposedly fully loaded. Im assuming around 120k miles.
Heat soak on the middle injectors. Run the car for awhile, then shut off and try to restart. It's easy to fix but if it's hard to restart, that's a few dollars off... ;-)
Check the temp. Should not go over 210 on gauge. If it does, probably has overheating issues. Scale and rust in radiator overflow is pretty common.
Good luck
oh, of course the Dana 44 is more desirable than the Dana 35's...if she plans on wheelin' or putting larger than 30" tires on it.
