Looking for info on these. I got a 4l60E out of 99 suburban with a 5.7L SBC. Appararently they only made these two piece bellhousings for 4 years before they switched to the LS style bellhousing. Anyway, it has a spot for two braces that bolt to the bottom of the bellhousing and attach to the motor mounts. I do not know if they used the braces since 96 or if they used them in 2WD at all.
I cant find any info on them, all I find are the Tcase braces.
Here are some low res screen shots I have captured from a quick scan of oil change and starter replacement videos...
I got questions....
1 - do they use the same sandwich plates from the motor mounts as the older transmission braces, or are those parts different?
2 - do they clear regular oil filters?
3 - does anyone have a set?
I got questions....
