verceingetorix
Registered Member
The expo is an XLT with 130,000 miles the 5.4 triton, E4OD tranny (rebulit from ford with transferrable warranty 3yr/36k.) Was installed on 8-08-05 and had 116,646 miles when done. It has front/rear heat and AC, power driver seat, PD, PL, cruise, 6 disk cd, tow package, and third seat. Has a 6" Fabtech lift with 4.56 gears. The tires are 37x13.5x17 Toyo MT's with about 60% tread mounted on 17" Atlas wheels. It is in great shape overall inside and out.
The bad is the driver side window motor is noisy needs to be fixed but still works fine, also has a leak on the t-case output. The only things that will need attention is the power window motor and the t-case seal.
Will trade the expedition for a samurai and cash.
The Kelly blue book is $7,840 I am asking $6,300 The lift, gears, tires, and wheels, alone are about $4,200 new. You can pm me or call 1-208-234-1535 ask for Bart.
