trailblazr81
OK so what I am wanting to do is mate a NV4500 from a 1998 K2500 with 6.5 Diesel to an old small block 383. Will I need an adapter for this or will the tranny bolt up to the 383?
As mentioned above, the transmission will bolt directly up to your 383, and the internal slave cylinder does play nice with the factory smallblock clutch & flywheel.
That said, while the NV4500 is an extremely beefy transmission, it drives like the medium duty transmission it is, don't expect it to shift like the light duty 5 speeds do!
what happened to the 6.5.....
