So I bought this van and the owner said it will start with the starting fluid then it will run forever.
True enough so I got it and trying to figure out why.
I checked the fuel pressure and it is right at 58psi and it doesn't drop after 10 minutes, battery was a little weak so I changed it, no change.
I know that the injectors on these engines are problematic but I have only seen them misfire one or 2.
This new to me.
Anyway I already had planned to upgrade to the better setup so I bought them but still not had time to put them on.
Anyone care to venture and analyze why it wouldn't start but once it did it runs fine and smooth?
Hopefully at the end of the week I can put the new injectors and see if it solved the problem.
My buddy insisted it's the pump because he read somewhere anything under 60psi is not enough.
I know not a single regulator from gm is 60 psi so 58 is just fine.
Could it be the IAC, or any other sensor that is not working?
This new to me.
