88sub4x4
Hi all. I'm stumped. Trying to fix my buddy's truck. It's a 1999 K2500 classic (not a silverado) with floor shift transfer case. About a week ago his 4wd stopped engaging. I checked out a few things and found it would intermittently engage and the indicator light would illuminate. I changed out the actuator and now it engages every time the floor lever is put in 4wd. But....the indicator light no longer comes on. The 4wd is definitely engaging and disengaging when it should. I checked the bulb and it is fine. I also replaced the switch on top of the transfer case thinking maybe that was bad. I'm at a loss. What turns this light on? Do I possibly have a defective actuator? Thanks in advance for any help.
