Usually only does it when it is cold and wet outside or if the truck has been sitting for a while. When I try drive out of my driveway, my rear brakes lock up (feels like it's only the driver side) by just slightly tapping on the brake pedal. It's only the rear brakes, and I can be going anywhere from 2mph to 10mph and the truck just stops on a dime and feels like the axle is going to rip out of the truck. This will last about 3 blocks. It will also do it at random times while out plowing snow and may last a few minutes which sucks when the brakes grab so hard. I've checked everything and even had a shop put new all new drums, shoes and wheel cylinders on it last winter. I've taken it back a couple of times and they can't find anything wrong with it. I've seen other people with the same problem but, can't find where anyone found the actual problem.
