It has gray, black, purple and black with white stripe.According to the service manual the pump runs off of the ecm-b fuse in the under hood fuse block. It's obviously not blowing or else it would not work after it quit.
My guess is you got a bad ground or high resistance on the ground side from the pump and it's drawing more current than the motor can handle and it's quitting.
Your new pump came with a new connector right? Make sure you didn't swap the grounds for the sender and the pump. The ECM would not like having that current come through on the signal ground. Kinda sounds like you did based on how the gauge behaves.
The schematic shows both wires are black (big help right) but the fuel pump ground is the larger of the two wires. Terminal locations on the original connector would be terminal c for the fuel pump ground and terminal d for the sender ground.
They're all matched up on the new plug and wires.
I have done this 3 times now, the fuel gauge pegs and the engine doesn't start.
Unhook the battery for a few minutes and then the gauge works and the engine starts, runs for a few minutes then back to the same problem.
