1st gen front springs vs. 2nd gen
destinbeachman
Florida
I have a set of new 1st gen TC EZ-rides that I never used and a buddy is needing a set for his 2nd gen.Are these compatible?
so if you put second gen springs on a first gen it would give it a better shackle angle over a first gen lift spring, right?
probably but it would also move your axle back an inch.
Is the distance the same from center out on each end? i know the fords are shorter on the front but cant say i ever really looked at the ones on the blazer
