2 5/8 hole saw
kgblazerfive
keymaster
Hooper, Utah 84315
Need one for my gauges, anybody have any idea where to get one cheap.
and do I need a 2 5/8 hole if thats what size the gauges are?
I got mine at either Lowes or Home Depot. I don't remember the price but I also don't remember it being expensive.
If you can't find a cheap one, holler an I'll send you mine and you can send it back whenever you're done.
Did you buy the gauges yet? Measure the hole in the box that they come in and it should tell you what size you need.
if its an autometer 2 5/8" you need the 2 5/8".
Box is a thought I don't have the box for these, but I have a complete other set in boxes so I will do some figuring.
I watched an episode of grease monkeys where the guy was trying to measure the gauge with a tape measure to figure out what size hole to cut... spent way to much time with no results until someone walked up and showed him the cutouts in the cardboard box.
As long as you aren't using angle rings then it would be a 2 5/8" hole, if using an angle ring then the hole will need to be oblonged in the direction of the angle on both sides.
