2.5" rear block, tapered with ubolts
jjlaughner
3/4 ton status
Indiana
2.5\" rear block, tapered with ubolts
Looking for a tapered 2.5" block like this
with ubolts for 10bolt or 14bff either one
the cheaper the better
Re: 2.5\" rear block, tapered with ubolts
are they tapered? do you have any pics of the blocks.
Yes, they are cast steel, tapered blocks. i will try and get a pic out to you in a day. They weigh 25lbs! I bought them from another mamber, but never used them. The 89 came with blocks in it alreay.
yeah I'm debating using the 2.5" blocks or a 2.5" flip to level out the truck. I have a zerorate in the rear and it needs to come up about another 1". Then I'm wanting to put the zerorate you front and push the front axle forward a little (then I'm back at the same problem I have now with the height). I was thinking about a 2.5" tapered offset block also. So I'm not 100% whats the best way yet. /forums/images/graemlins/tongue.gif
Do you have a Fed Ex drop off close to you?
I have a Kinko's nearby, that about the ONLY fed ex place I can be sure I can get to with my new work hours. There open 24/7!
wow, those blocks look so familiar....
sent PM
need anything for trade?
sold, pm'ed and paypal'd /forums/images/graemlins/waytogo.gif
