fallguy
Alright fellas i have a little dillema.... I recently sold my axles/tires/wheels off of my 84 longbed 3/4 ton. I have a D60 to build up but no rear. Got a quote on a fully built newer model 14 bolt to go with the front, quote was good I waited a little to get the cash & now the core is gone
So now I have been scratching my head thinking. Would it be cheaper to build a front steer/fixed rear set of rockwells or continue with my current plan D60 front 14bolt rear? I would obviously sell the D60 if I go the rockwell way.
Brakes are my big ? on the rockwells, I would like to drive it on the street occasionly but mainly trails. So I was thinking the ouverson super 8 kit but
its a little pricey.
If I go D60/14 Bolt I'm expecting to spend around 6K
little more than I would like to but by the time Find a rear, gears, locker, disk brakes, truss. Then build up the front that I have wich will need single wheel hubs, knuckles, steering arms, gears, lockers(5.38 gears for 42-46" range tires) I expect to be in that range.
Do you think I could build or buy a set of rockwells for close? I've found some for around 1400 for the set, then i would need to get brakes, steering, etc...
Who is running the Roks? Would you recommend them to me or should I stick with my original plan? How bad is the install on a truck like mine?
Like I said, I will drive it on the street every now & then so I think pinion mounted brakes is a no no. Let me know if you need more info, sorry for the long thread
its a little pricey.If I go D60/14 Bolt I'm expecting to spend around 6K
little more than I would like to but by the time Find a rear, gears, locker, disk brakes, truss. Then build up the front that I have wich will need single wheel hubs, knuckles, steering arms, gears, lockers(5.38 gears for 42-46" range tires) I expect to be in that range.Do you think I could build or buy a set of rockwells for close? I've found some for around 1400 for the set, then i would need to get brakes, steering, etc...
