GsxrMike
I remember reading somewhere that a 2 bolt main 400 small block is actually stronger than a 4 bolt? Is this true and if so why?
To add to what fried_guy said, a 2 bolt block that has been converted to a 4 bolt with splayed caps will be the strongest setup. But that is only nessasary if you're turning some serious rpm or planning on more than 500hp.
And to explain what splayed caps for those who said Huh???
That is a cap that uses the 2 bolts from the original 2 bolt block and adds 2 more at an angle which gets to the stronger part of the web on the block and the fact it's at an angle makes the bolt work patly in sheer on top of pull on the threads.
Much stronger than a 4 bolt main.
Sorry I forgot I that I was talking about a 400. I will do some research and see if I can find a kit or does it matter?
). That's only for 350 based motors though, as the 400's have differn't sized mains. I don't think there would be one for a 400, since they were never one piece seal from the factory. Even if you did find one, the cost wouldn't really justify it.
