WJACKSON11X
My rig sat for almost a year. Recently decided to get it going again, so I went to crank it up one day. Started to sputter and die frequently. I figured the gas was bad and caused some issues in the fuel system/TBI. I replaced fuel filter and added some seafoam. A couple of days later I went to start it up, but nothing. Found out the fuel pump had taken a crap. Replaced it 3 weeks ago and it ran fine. I've cranked it every couple of days just to let it run. I bought a camper 2 weeks ago and have been busy fixing it up. Well, the other day I went to start the Jimmy and I noticed no fuel pump noise. checked relay and power at the pump. Had 12v but no pump action. Removed the pump today and checked it by putting 12v directly to pump, pump was dead! Went to town and swapped it out and installed the new pump. What do ya know, now it's running like top. What would cause the pump to go out that fast? Was it just a bad pump? Hopefully. Is something else causing the pump failure? I did install a new strainer the first time and didn't see any trash on it. Just thought I would ask and see if anyone else had the same issue.
