2 gen 14 bolt rear disc
i was just wondering if anyone new on here, i know ive been searching for awhile to find one and there was prolly some other guys looking to. just figured id post it up
some late van axles still used non pop off drums.
do you have the drums pop off the front style or have to remove the whole drum hub unit ?
if pop off then the kit you linked.
if non pop off any old style kit will work.
reason is the pop off stuff went narrower spacing on the bearings = shorter hub and spindle.
same problem
im going through the same problem, i think the brackets listed should work, but im wondering about the rotors, ive read the the van hubs dont work to well for rotors like the older generations do.
problem is pop off drum style runs 1" or so shorter spindle spaceing of the bearings.
also the pop off drum is not machined on the backside. some have good luck some get vibrations.
i tryed disk kit for old style 1 time not knowing the diffrence. it didnt turn out right at all.
you cant swap on the older hub's to the newer pop off drum style spindles. so if you need any parts thay need to be for the pop off style brakes.
