2" Lift kit
ArizonaK5
Goodyear Az
2" leaf spring lift kit front and rear. If I wanted to lift the suspension 2" more. Would it be safe to use 2" blocks front and rear? I ve seen them in the rear. Not sure about using them in the front?
No blocks in front! Closest thing you could use would a 1” zero rate, which bolts into the spring pack and maybe some longer shackles and that would probably get you to 1.5-2”, though the shackles are going to hurt you pinion angle. Otherwise, new springs for the front. Rear you can use a block.
I would do 1" zero rates . Then new body mounts and 1" body lift . And in blazers you hit 4" you tend to need a c/v rear drive shaft .
