2" LIFT WITH 35's?
Re: 2\" LIFT WITH 35\'s?
If you do you will need to remove most of the back half of the front inner fender. If you run a lot of mud or water that might be a problem. Otherwise just cut untill they don't rub. You may need to take a sledge to the floor pan, though.
Jim '80 GMC & '73 Blazer
Body by Tellico
<a target="_blank" href=http://www.tellicok5.rockcrawler.com>www.tellicok5.rockcrawler.com</a>
why would that be a problem??
-Zakk
'77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
CK5's MOAB 2002 OR BUST!!
