DEMON44
Low-Tech Redneck
1- who makes a 23 spline female input for a big bore 205?
2- who makes a SYE kit for the 241s?
I thing the 23 spline is Dodge, the 23 spline is male with a coupler. The OD od of the 23 spline takes the big bearing NP 205. Dodge used an adapter to change a figure 8 to circle 6 bolt pattern.Is there a reason you're using a big bore 205 over a small bore--doesn't the stock 23 spline input fit the small bore 205?
Edit, It appears Dodge didn't offer the NP205 in 23 spine but 29 spline.
Quad 4x4.
