2wd box = full spline sector shaft. center nut/lockwasher held on arm.
4wd box only 25% of the sector shaft is splined. and arm held on with pinch bolt.
and 2wd turns backward of 4wd box. so if you wanted to use a 2wd box on a stock steering 4x4 axle left would be right and right would be left.
